830 fuel pressure gauge starting point
trak
have a new gauge, about it, only plugged outlet i see is on the return from injectors? don't seem like that would be it, idk
If you posted previously on this subject I must have missed it, restate your problem, does your engine run, miss, describe problem the front fitting on the outside of the injection pump where the return line to the injectors fastens is a very tiny restrictor fitting so only expect a tiny stream there shooting out while running, it is just to purge air out of the fuel rail in the pump.
If your question is "where do you connect the gauge to the fuel system". All of mine hook into the fitting on the bottom of the final fuel filter.
