Case 310g: left side steering stick
rbp
There isn't much action at all on the left steering stick on my Case 310g. I pull it back till it hits the seat. Is there an adjustment that I can make? Right side is good. Thanks.
Just go to the back and look under the fuel tank There is an arm coming out of the top of tranny on each
side. Tighten the nut on the rod from left lever. Simple and straight forward adjustment when you look at
it.---------------Loren
(quoted from post at 08:53:29 07/28/19) Just go to the back and look under the fuel tank There is an arm coming out of the top of tranny on each
Thanks! I've been trying to look at parts diagrams on the Case Online Parts website to see if there was adjustment, but the website would load up. Not sure why. Thanks again.
(quoted from post at 18:21:41 07/28/19) I suppose you know there is only a brake band, no steering clutch.
Thanks again. It is probably the original brake band.
(quoted from post at 04:59:27 07/29/19) I would agree. just remember it takes mineral oil only in the brake band housing.
Thanks again. I greatly appreciate your help.
I bought a service/parts manual years ago when I had my 310. still have it if interested. jus email me.
