Company Logo Shop Now
TractorLinks.com
Re: 351 carb
kenbob
07-21-2019 16:14:28
joe, would you know which needle is too lean--Power or Idle?
kevinthefixer
07-21-2019 18:31:06
 Re: 351 carb in reply to kenbob, 07-21-2019 16:14:28
If it's happening with the throttle butterfly closed, it's idle mix. A leaky exhaust manifold or gasket or headpipe can also cause that.
kenbob
07-21-2019 19:47:44
 Re: 351 carb in reply to kevinthefixer, 07-21-2019 18:31:06
Thanks, I need to recheck the manifold. I switched it from up flow to down flow and used new gaskets but i am a chicken when it comes to tightening old stuff...especially manifold nuts or bolts. Really don't want to twist one of those off. I may need to feel for leaks and retighten.
chuck machinist
07-23-2019 13:55:43
 Re: 351 carb in reply to kenbob, 07-21-2019 19:47:44
I feel your pain when it comes to torqueing intake and exhaust manifolds. Stay within the specs, and if it continues to leak , you resurface ,and or replace with a gasket. CM. Gremlins no longer live in my shop! But they live just outside the door.
kevinthefixer
07-22-2019 05:03:19
Hold a rag in the tailpipe while it's idling, or have someone else do that while you feel and listen.
kenbob
07-22-2019 07:00:11
 Re: 351 carb in reply to kevinthefixer, 07-22-2019 05:03:19
You probably nailed it. When I got the tractor last year I took it on a ride. It was lean then and had to run with the choke out. Since then we got the carb working by taking out the economizer valve and I did the change on the manifold from up to down. It ran great on short trips. I am guessing that is where the problem is. It probaby loosened up a little after some run time.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
