Headlight bulbs for 312 case
r.w.b.
I was using my 312 case yesterday,noticed 1 headlight was burned out. I looked everywhere cant find 1. The lights are the same body as the lights used on most tractors in early 50s and before but has sealed beam bulbs instead of the big bayonette bulbs like a dc ,m ihc,a jd used.
Anybody got a source for them? My 312 is low hours im second owner not wanting to change lights. Its just needing side panels then its ready to paint
I believe they are of a size that was not common. My tractor had a set of aftermarket square lights to get around the problem. Luckily the previous owner did not take off the old ones. I don't remember exact size anymore but what I did was get the closest smaller size and big roll of black electrical tape. I wound the edges of the new beam multiple times until I gained enough size for them to stay in the original cans.
You have to wrap a bunch of electrical tape around a 4411 bulb to clamp it into the housing and a 4411 is 12V. 4411's work in the nose of the B series and all the 30 series.-------Loren
I am doing better. Managed to get a few short afternoons working up in the woods, but have to compensate for the pain when I get home. I need to get my back muscles back into shape, so I can beat this thing. Not sure whether pain is from my tumble, or the Diverticulitis. Seams that all the good doctors have left for greener pastures around here, so getting an appointment with a back specialist or a GI doctor takes months. --------Loren
Ok thank you,go to case ih and offers complete light.
I want this tractor to stay original, very low hour tractor
I once had the same issue with a 311, After removing the old bulb, I measured it. Found one very close, bur slightly smaller, at TSC or NAPA. I then wrapped the new bulb with some black, flat, foam insulation used to plug drafts in doors & windows, Clamped it down, worked like a charm.
