I have a 52 Vac 14 that was running great and then it started sputtering and not running good. I assumed it was fuel so I started checking things. The
sediment bowl was fuel of a lot of junk so I figured I better check the tank. I pulled the tank and drained it. While draining it thru a cloth I found big gray
chunks of liner. Someone has lined it and the lining is coming loose. Luckily I have a spare tank. I also pulled the carb so I can go thru it and clean it.
