SPITZEGESCHOSSE
New User
hope someone can steer me in the right place. makin bales yesterday pushed in the clutch kicked bale and that was it. no more forward or backward movement.
1)you dont hear the surge when you depress clutch.
2)it does actually move a bit when you put it in gear and release the clutch.
3)hydraulics, steering and PTO still work fine.
4)changed trani filters last year and oil does not look dirty
5)pulled one of the springs on the side power valve body cause that was advice i got from another source
6)NO idiot lights on the dash are on. all looks good there
7)gonna go get a 300 psi gauge and screw it into the side of the body at the pressure regulator switch and see if she has the 210 psi buddy says it needs
