Company Logo Shop Now
TractorLinks.com
DC case mag
ajdeereman
07-14-2019 17:35:37
Can you put a distributor on a DC case in place of the mag if so what tractor would use a MAG from
mEl
07-15-2019 15:14:12
 Re: DC case mag in reply to ajdeereman, 07-14-2019 17:35:37
The IH distributor is a nice option also, just be sure the bushings in the distributor shaft are tight. Either unit can be updated to the Pertronix module. The pertronix module does compensate for bushing wear as variation caused by shaft movement does not matter as there are no points whose gap can be affected by shaft wear. If you are considering a pertronix I would opt for the Ignitor 2 as it is more forgiving of coil primary ohms as it will adapt to both high ohms or low ohms secondary.
tractorguy2
07-15-2019 12:48:40
You have three options.
Delco Remely conversion distributor
delco distributor off an Allis Chalmers WD. very similar in appearance to the conversion distributor mentioned above.
IHC distributor off a GASOLINE FARMALL tractor model H through 450.
tractorguy2
07-15-2019 12:51:50
 Re: DC case mag in reply to tractorguy2, 07-15-2019 12:48:40
The Allis Chalmers distributor must be off a WD or converted WC. A WD45 distributor is different and will not work on a DC Case.
mEl
07-15-2019 06:37:34
That unit with the upright distributor was a mag replacement made by Delco Remy, The number I believe is 111411 distributor. they are getting a little harder to find.
countrycase
07-14-2019 18:30:36
Yes you can change a DC over to distributor. I did mine plus changed it over to a Pertronix electronic ignition. Fires up with just a tap of the starter button. You will just have to look at the adds for a distributor. I found mine on here
ajdeereman
07-14-2019 18:49:05
 Re: DC case mag in reply to countrycase, 07-14-2019 18:30:36
What tractor did use a distributor from
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
