D or DO battery base needed
I took a 1/4 inch plate of the same dimensions of the old base ,and drilled and tapped two 1/4 20 holes at either end of the long section for hold down brace studs .Are you looking for OEM? CM
Right now I?d just like to have a better base for the battery. The one on there is pretty corroded and rusty. I might look at making one. Should have got an extra d for parts at the auction last sat. The scrappers ended up with some of them pretty cheap.
