600 vs 900 Case
Tin work, dash is about it on a plain 900, 900B add in front axle wheel rings making the wheels a few inches wider on each side, and a inline injection pump, powertrain is the same between the 600/900/900B other than later pump and the block has a casting for the tach drive
cnt
Both have hard pullin drives, these tractors were worked hard, and asked for very little especially with a hand clutch. I would say they were some of the finest tractors Case built
Aside from what Nutty said, the front axle and spindles are completely different between the two. The 600 uses same arch axle as the some of the 500's use. The 900 uses a straighter axle, but the spindle is lowered to effectively raise the front. The pivot pin mounting is also different. The pics shown demonstrates the axle differences.
