53 case dc voltage reg
Good night gentlemen
I have a 53 case dc-3 tractor ( foot clutch ) I am looking over the electrical system still factory 6 volt magneto inigtion. I hear some debate but I think Racine tractors were negative ground ?. But auto light ghd6001c generator uses a two charge regulator to maintain the battery voltage. There is a twenty amp fuse in the light switch and a 5amp fused in the voltage regulator and all the after market cut out relays say 15 amp 6 volt I don't know if I have to watch for polairity and is 15 amps enough to keep the battery charged as currently after running awhile the light start to pulse and now charge.the battery test good but thinking about rebuilding generator but no one seams to be able to find voltage regulator/ cut out but after market the closest I have been able to find are for a cj2 jeep
Any thoughts and help would be greatly apreciated as wiring generator novice thank for any help Bob
I sure I am getting tired so please for give the poor proof reading and fat fingers
The above post should read after awhile the lights pulse and the battery is non charging
Bob
Unless you want to keep it all original, change to an alternator. They have more amps of output and easy to mount and wire.
dc in Illni; there are some really smart people on this site that know and understand the 6volt generation and regulator system. I am not one of them. I tried a few times to maintain the 6 volt system, but even with Bob's and John T's and others explanations and diagnostics I had troubles. So I made the switch to an alternator. And since have enjoyed a trouble free system. My 52 DC with mag has a alternator, great tractor no electrical problems. At present I have 3 or 4 old generators on the shelves in the shop. IH and Case, they will go to the scrap man one day, I'll never reuse them, and it is expensive to get them reworked. gobble
