I got another G1103 inside hydraulic control lever to replace the broken original. I found a thin nut to use as a spacer since the pivot bolt shoulder is 3 3/4 and the 2 levers are 3 3/8 combined. The rear rod for the depth control needs another 1/4 inch of spacer to line up with the depth control lever that should be G14381. I tried threading a thin nut against the pivot bolt shoulder and this lines the rod up but there are only 3 or 4 threads left for installing the bolt in the casting. Also, the rod clevis catches on the depth control quadrant before reaching the stop if adjusted to max so something isn't right. It looks like the offset bend in the depth control lever is opposite of what it should be but is correct according to the parts manual pictures. There is a number stamped on the depth control lever that looks like G17062 but I can't find anything with that number. I would like to know what is going on before I start bending factory parts to fit. The tractor S/N is 6129719.
The torque tube was low on oil and transmission very full when I drained them. Can the same fluid be used in both in case fluid moves between compartments?
