Case 1070: No remote Hydraulic
BeeW
New User
Looking for help. We recently had a case 1070 power shift unit completely rebuilt, we got the tractor all back together and now have some issues. The power shift seems to be ok and working good, do not however have any remote hydraulic pressure and the lift arms will not raise when the inching pedal is up. Pressing the clutch down allows these to both work.
Sounds like you have a severe leak in the powershift circuit, shift through each powershift while watching the hitch and see if it lifts in some ranges but not others. The flow divider satisfies the powershift before it sends oil to the remotes and hitch and your statement that the hitch will raise when the clutcch is depressed says that the leaky circuit is shut off when the pedal is down. Check hitch as I said and write down your results and post back.
