610-b
brian stanek
01-28-2019 15:04:47
I have a 1959 610-b parts tractor. it does run but without power steering and no tin work and trans issues hope to get some good parts off it. does anyone know if the torque would be the same as my 580CK? also any chance the trans and rear diff parts fitting the 580? I will probably tear it down some time later this summer.
brian stanek
01-29-2019 07:30:22
 Re: 610-b in reply to brian stanek, 01-28-2019 15:04:47
thanks a lot for the info. was hoping parts would be the same but will do as you say at some point and see just what may be good to keep and get rid of rest.
mEl
01-29-2019 06:26:47
TC is not the same, the transmission on a 610 is heavier and physically larger, some internal gears in the 4 speed portion may work but no guarantees, you will need to do part number comparison for interchange, Although they look the same they are no
