Case 530 D. Is farm fleet hytran ok in trans ?
530D dry clutch , what are you guys
using ? It don?t get a lot of use . Reason
I ask, is just got seal, gaskets to rebuild
lift cylinder , and the hytran is what I used
before the seal went out . Wonder if
the oil was cause of seal failure?
The 3 point Isnt used that much
I believe this model would be similar the 431 that I own. There is the transmission which takes 80/90 gear lubricant. The torque tube uses a Case designated hytran fluid. The container has the Case designation along with other manufacturers that use the same fluid on the label. Can?t recall the exact Case number.
I guess you don?t have an operators manual? This would tell what is required.
Jim
