I am restoring a 1958 Case 310B and having trouble with the Power steering.I have put a new p.s.pump on and replaced the o-rings between the barrel and cylinder.It will turn all the way to the left, but won't go back to the right unless I use the loader to raise it off the ground,then it will go both ways, but with a good deal of effort back and forth.The o-ring kit came with an extra o-ring a little larger than the two small ones.Would this go on the threaded bolt, maybe back by the spacer washer?The hoses are installed correctly according to my service manual from Jensales, top hose to outside.Any ideas? Thanks, Bob
