Tractor/Loader
grybnsll
New User
I have a 1570 Case and a chance to buy a John Deere 158 loader. My tractor hood is 32" wide and the frame is 26.5" outside to outside. I understand the JD 158 is a good heavy loader but does anyone know if it will fit my tractor?
Not a direct bolt on, will have to modify the mounts. Also if it has a valve,it will have to be changed to open center.might be alot easier to find a loader with case mounts
From what I have seen of JD loaders, many use small bore hydraulic cylinders and run high PSI pressures. There might be better choices for a 1570.
