Stoneman44
Can someone diagnose this?
[video play=false:c81d62c5e7]https://forums.yesterdaystractors.com/videos/mvvideo27170.mp4[/video:c81d62c5e7]
A little background. I have NEVER had a problem starting this tractor from the day I got it.
Here's what happened when the problem started. Thanksgiving night I was unloading a gun safe from the back of my pickup. I had the Brown backed up to the truck with a platform on the back to load the safe onto. The tractor was idling for approximately 20-30 minutes as I had to retrieve a rope from the barn to pull the safe to the rear of the tailgate. As I began to move forward, the engine began to race, revving up to approx 1800 rpm, but then it settled again to idle, 750rpm. I put the tractor in reverse to back to my house door and it revved again, for about 4-5 seconds, then settled again. I backed the tractor to the door and shut it off. I was unloading/moving the safe into the house for about 20 minutes. I returned to the tractor, tried to start it, and it did what you see in the video. I finaggled w/ it for about 10 minutes and it eventually started. I parked it in the barn until today.
This evening, I noticed when starting it, the tractor was a little more hesitant than usual. It started on the first turn but it wasn't as quick as normal. I attached my hay spear, drove to the hay barn, got a round bale, removed twine and parked the tractor back into my barn. All this took maybe 30 minutes. I thought I'd try to restart the tractor to see if everything was OK. It wasn't, the video is from this evening. I walked away for about 5 minutes, went back and it started. Turned it off and it went back to this. I did get it started a second time after 10 minutes or so. Shut it down and this again. I did notice a few times that the tractor seemed to "burp", nothing big, just a short, almost grunting sound.
I don't believe it to be electrical, as I can continue to turn the key and it attempts to start for a couple of 10 minute sessions. It almost as if there's something keeping the engine from turning over. I can feel the crankshaft turn over then stop abruptly, like it feels as if it gets stuck.
Thanks for any help.
