mechelement
My ‘64 Case 440 is giving me fits again... The tractor sat for a few weeks and when I started it, it chugged at all RPMs with low power and poured black smoke. I shut it down and when I tried to restart it, the battery couldn’t turn it over. So I charged the battery until it would start. Then it ran great.
After that, the tractor sat one week and when I started it, it chugged at all RPMs with low power and poured black smoke. I had to rake in front of the loafing shed and get the tractor out of the pasture. I unchained the rake and shut it down. Then I restarted it and it only chugged at idle. When the throttle was higher than idle, it smoothed out. So I parked it and checked the battery. I put my Battery Minder charger on it for a 2A charge and desulfurization for 24 hours. It started out as weak and when I checked it after 24 hours, it was strong.
I got it ready to start, went from Reverse to Start and BZZZZZZZ SNAP! Definitely electrical zap and a pop. It wouldn’t turn over the engine. I’ve tried multiple times and it strains like the flywheel is stuck. The starter is engaging, it just won’t turn over.
I’ve had this thing act like the flywheel is stuck before, but just let it sit for a bit and it finally started.
Any ideas of what I have going on here? Will a weak battery cause this thing to run rough? Should I put a breaker bar on the crank and manually turn over the engine, then try starting it? Bad starter? Bad solenoid?
