Neal Ochs
Have 49 LA Case that I have been working on. Wanted to pull the pully off the front of motor, do you have to use a puller to remove this pully? Tring to clean front of motor up, have radiator off so doing a little clean up. I apricate your help.
You will need a puller. I wouldn't take it off if just cleaning...easy to break. Probably need to remove the front bolster to get enough room the get a puller in there.
