Case 770 Rocker Arm
To change the seals on the rockshaft you will need to remove the rear platform mounting brackets and support the rear of the platform. The arms will slide off after removing the snaprings on the end of shaft. Most often a leaking seal has the shaft oiled well and the arms come off rather easy but some do get rusted on. Now the seal can be pulled out, I myself drill a small hole in the seal and pull it out with a dent puller. Sometimes the bushings are worn allow to much shaft movement causing the seal to leak and to replace those is difficult, we won't get into that unless need to. Rod.
