Hi again all,
I'm trying to identify where the puddle of dark oil on the floor in the attached photo is coming from. From investigation, it looks like it might be coming from a leaking hydraulic tube (2nd pic), but I'm not sure. Although there's plenty of weeping around that area. I tightened the nut, but it was already very tight. Any ideas? Sorry if this is a dumb/obvious question but I'm still learning.
Also, what smells like gas appears to be leaking from this bolt area in front of the eagle hitch. This seems an odd place for fuel to leak. Should I be concerned, or just tighten the nut up as best I can and live with it? For me, though, loose fuel has a high pucker factor.
Thanks for your collective wisdom.
