I need some guidance to adjust the clutch on my 1070 as my service manual won't be here till next week and I really want to get this done before the cold stuff hits.
The clutch does not seem to be totally disengaging as I get a bit of grinding when selecting a range. Once it goes into a range I can change ranges OK till I put it in neutral and leave it running for a bit then I have the same issue again. It does not change at all when the tractor warms up. I did have some sticking of the pedal when I first brought it home that I cured with cleaning the pivot point on the pedal and then using some lubricant on it. Now the pedal seems to be coming all the way up.
Any help would be great
and thanks again
and thanks again
