compression onlow compression head?
From my perspective: having near uniform readings across the cylinders is more important than how much. I have 3 compression testers and will get 3 different readings on same cylinder if I check with them all. That is on engines in the 200# plus range. May not be much difference on lower compression engines but will look like more.
In my experience any compression less than 75 psi requires attention. New Rings or valve grind or both. SC regular head with pop-up pistons I would expect to be 120-140. Regular pistons 90-120. Low compression head 80-100. And as mentioned fairly even on all four cylinders.
Also: compression should be a bit higher on warm engine over cold. Also be sure carburetor is wide open when checking. Limiting air into cylinders will reduce compression.
(quoted from post at 04:48:00 10/02/18) Is that with a little oil in the cylinders?
find it good practice to run it "dry", that is without adding oil to the cylinders, first then do it again after adding a tablespoon of oil or so. A large increase after soaking the rings with oil indicates worn rings as a rule of thumb. Does your tractor run poorly or smoke a lot? Are you trying to solve a problem or just trying to get an idea what shape your engine is in?
