580E Noise at Idle
Part Time Pete
I have a 580E backhoe that seems to have developed a clatter at idle. When you bring the RPM's up it goes away. I'm not sure where it's coming from, but seems to be in the area of the injection pump. Any thoughts?
Thanks
Pete
May seen like a far out suggestion but I spent many years with all series case hoes and the first thing I would check is to see if the motor mounts are pounded out. that is the biggest cause of rattling complaints by far. the engine will literally move around some fare enough to allow the muffler to wear against the hood hole
