Case 430 Hydraulics
ibreck
New User
I have a 1968 Case 430 gasoline tractor. Been leaking hydraulic fluid for some time. I can't find anyplace to add hydraulic fluid, only the 1 1/2 inch transmission bolt with a 10" dipstick in from of the seat. The fluid level there is at the notch approximately 2 " from the bottom of the stick. Anybody know how/where to add hydraulic fluid???
If you have a triple range tractor, look on LH side of torque tube. The fill/dipstick is behind the hand clutch lever. (First pic). If you have a dual range tractor the fill/dipstick is on the RH side up on the top cover, under fuel tank, (second pic).
Loren
(quoted from post at 09:07:42 10/01/18) If you have a triple range tractor, look on LH side of torque tube. The fill/dipstick is behind the hand clutch lever. (First pic). If you have a dual range tractor the fill/dipstick is on the RH side up on the top cover, under fuel tank, (second pic).
Loren
Thank You! Found it. Based upon your pictures (very helpful) I have a dual range tractor but my fill/dipstick is somewhat obstructed by hoses and linkages. In any case do you know how much fluid it holds?
He stated that the tractor has a loader with leaks and the only dipstick he could find was for the rear end, and it was on the mark. He just could not locate the fill/dipstick for hydraulics. Case was pretty good for hiding them depending on the tranny that was in the tractor. He also posted over on R&R forum on this site, where he mentioned the loader.
Loren
My 530D the fill is next to the hyd. valve
/filter housing on top of the trans under the dash on
brake side. 1 1/2 " plug
Hey Loren, thanks very much for all the info. Do you know how much hydraulic fluid it holds? I'm just trying to confirm the amount. I have a Case 430 service manual and if I'm reading it right (for the serial number of my tractor) and the fact it's a 4 speed it's telling me it holds 24 quarts "in the Torque Tube". I'd really appreciate some input here. Thank you!
I don't have a manual here to tell me oil capacities. Maybe some one else will chime in with capacity.
I presume that your tractor has the dual range with 4spd, giving you 8 spds forward and 2 reverse.
Loren
