Case 200 gathering firewood
The Case 200 got out from under cover to help help gather some firewood for a friend with back problems. Too much rain has made the ground real soft hence all of the forward weight on the cart. The 200 has no weights or ballast in the rear tires and there was a steep hill to climb.
[/img]
The long bed S10 cart had more than she wanted and it was all wet oak wood that had been laying on the ground. Sometimes you just don't want to stop finding another log to throw in.[/img]
I'm not sure if has sleeves or not. I've been told it's a VAC style engine and that is what it looks like. My 430 has the 148G engine which is bigger and has the generator on the opposite side. The torque tube is also smaller on the 200. I haven't been into either one of the engine's. Both tractors run exceptionally well. I've been through my SC engine which has wet sleeves.
The 200B series tractors has the 126 cid engine similar to the VA series tractors 124 cid and 300/300B/400B series tractors 148 cid. 430 gas tractor has 148B engine similar to the above 148 engine but larger crank journals and some other differences but still 148 cid.
Joe
Good to see your Case is getting the wood in! Makes it fun to have them around. Good post
