ltrasonic cleaning of my Zenith Carb
Chuck Machinist
09-22-2018 12:22:09
third party image
I found a gallon of denatured alcohol and decided to do a final cleaning of the carb with my ultrasonic cleaner. I chose not to use the heater option .We will give her a couple of hours CM
David G
09-23-2018 20:33:49
 Re: ltrasonic cleaning of my Zenith Carb in reply to Chuck Machinist, 09-22-2018 12:22:09
Let us know how that works.
Adirondack case guy
09-23-2018 17:29:19
Geeese Chuck, you just need to do a few more barley pop runs to the 711 with the 511 and it will run great. HeHe
Loren
L.Fure
09-23-2018 06:29:49
Mineral spirits and naphtha would be less flammable for your ultrasonic cleaner. Mix it 75% mineral spirit and 25% naphtha.
If you want to continue using denatured alcohol you should put the ultrasonic cleaner out on the driveway. It's not a matter of if it will catch fire, but when it will catch fire.
Mike Groom
09-22-2018 15:55:25
If you want to see your next birthday you might consider not smoking around that alcohol also! I couldn't help but notice the cig. in your mouth.
Chuck Machinist
09-22-2018 18:30:38
 Re: ltrasonic cleaning of my Zenith Carb in reply to Mike Groom, 09-22-2018 15:55:25
Good catch shame on me CM
kevinthefixer
09-22-2018 14:03:00
Haven't heard about anyone using ethanol (denatured or not) in an ultrasonic. Let us know how it works! I think most are using dish soap etc.
Chuck Machinist
09-22-2018 15:11:49
 Re: ltrasonic cleaning of my Zenith Carb in reply to kevinthefixer, 09-22-2018 14:03:00
Since I am replacing all the seals anyway ,denatured alcohol is my weapon of choice. Rubber seals and denatured alcohol don't mix. As I stated earlier, the heater switch remains off. I do want to see my 64th birthday in December! just sayin. CM
