Nick 831 tach drive
DKase
05-14-2018 09:14:47
Wet here this morning so I dug my tach drive puller out. It had a 930 drive on the puller when I found it. I was wrong on the thread size of the puller. It is really close to 3/4" but it is 20 TPI. The 70, and 30 series diesel tractors have the same drive. 90 series fits, but cable threads over the drive rather than into it like the 30, and 70 series. When you find one it will be the gear, and the entire sleeve as 1 piece, because the gear is clinched to the shaft, and the shaft needs to be removed from the sleeve out the opposite end as the gear is on. The part number is for the entire assembly. Gear is plastic, and all the rest is steel.
nick831
05-14-2018 11:04:27
 Re: Nick 831 tach drive in reply to DKase, 05-14-2018 09:14:47
Copy that. Thanks for the info. That will be helpful so I can build a puller. By the way I did finally post the pics of the old 830. Thanks for your help!
