case 3300 plowing
jim_uny
04-23-2018 13:26:03
would you consider this green manuring w/ a case plow ? sure does bury hi grass !
Paul A Young
04-24-2018 04:38:23
 Re: case 3300 plowing in reply to jim_uny, 04-23-2018 13:26:03
The idea of green manure was to plow under young legumes, such as clover or alfalfa, to provide N into the soil for your corn crop. That is mature grass that will definitely require N to decompose all of that mess.
tomturkey
04-23-2018 21:06:48
Around here the only time I saw green manure plow down was in the early spring after a hay field had gotten abought 6 inches of growth or in the fall after some regrowth from last hay cutting. While that gentleman is definitely adding organic matter to the soil, all that grass looks tall enough to be headed out. He is planting a lot of seed. What I don't know about green manure plowdown are the benefits other than organic matter. It will use up nitrogen to decompose/breakdown, but will it also add nitrogen, creating an overall positive for the new planting??? gobble
Adirondack case guy
04-23-2018 17:25:58
That video has been on here several times in the last 5 years, and that IS NOT a 3300 plow.
It is an OLIVER/WHITE built plow. Labled as a model 400 in the Case lineup, with either shear bolt or trip beams. It is not a hydraulic reset plow, which the 3300 plows were.
I thought we got you straightened out on the difference between CASE built plows and OLIVER/WHITE plows, but I guess not.!!!
Loren
FastFarmall
04-24-2018 09:04:12
 Re: case 3300 plowing in reply to Adirondack case guy, 04-23-2018 17:25:58
Well whoever built it,it's bury the trash pretty well, as a kid we always plowed down sweet clover,now that was in the later 50'S, we had a John Deere, and a Oliver plow,and they never did that good of a job of covering it !
jim_uny
04-23-2018 17:39:37
i bought an operator manual for 3300 powr-set(hydraulic) plow on ebay & checked it out. front cylinder is different and no hand adjustment with on land, so you are correct. my plow has white 549 moldboards that were added.
Adirondack case guy
04-23-2018 17:52:58
 Re: case 3300 plowing in reply to jim_uny, 04-23-2018 17:39:37
After Case started marketing Oliver/White plows they offered conversion O/W Radex bottoms that would bolt to Case beams, thru the parts system.
Loren
greenenvy
04-23-2018 13:53:05
Reading the comments it looks like a rebadged Oliver plow. Either way it’s a beautiful combination with the 6030.
