403 disc plow
Case Nutty 1660
10-24-2017 05:50:38
third party image
third party image
third party image
third party image
third party image
third party image
Been wanting to use this since I bought it some 15 years ago or more, This filed I have been working on getting loosened up deeper than 4 or 5", after many adjustments i have it set so it does not tail out, takes a bit of time to plow 15 acres only cutting 30" at a time but I am very close to being done,, the 970 is a bit over kill on HP but sure was nice to have a cab with our fall Windy/Kool weather
cnt
Bret4207
10-26-2017 05:29:41
 Re: 403 disc plow in reply to Case Nutty 1660, 10-24-2017 05:50:38
I have a 3 bottom trailer type disc plow of unknown make. Judging by the length of the beam, it may well have been a 4 bottom at one time. I got it in the hope that I could use it on rough pasture as people say they will cut roots and roll over rock/ledge. Darned if I can get it to plow right. Maybe it's our clay, but even starting it in a furrow it wants to walk right out of the ground and ride on the discs. All 3 wheels have cast weights on them IIRC. Have to get the time to play with it some more.
Ande
10-25-2017 19:43:05
Tom, this looks like 60's vintage, probably a 1966 and on? To go on a "930" or "1030"? Or pre 64? On a "830" or "730"?
Ande
10-25-2017 19:46:58
 Re: 403 disc plow in reply to Ande, 10-25-2017 19:43:05
I looked at your pictures below, think I got my answer
vac400
10-25-2017 06:23:18
Tom , Great pictures and nice to see the disc plow being used. Question, will the 770 pull that plow? If so I may need to look for one. Have a great day .Jerry from Ohio
Case Nutty 1660
10-25-2017 06:56:49
 Re: 403 disc plow in reply to vac400, 10-25-2017 06:23:18
third party image
third party image
third party image
Jerry, a 770 will pull one fine I hope you can find you one I finished up the field yesterday morning, the last couple passes I was rolling unworked ground, you can see what I was dealing with when I started working this field at first
cnt
Ronald in NWMO
10-24-2017 18:12:10
It is always nice to see how things are done differently in other parts of the country. Your country looks very different from what we have here in northwest MO. It looks like your plow is doing a good job. Thanks for the explanation on the disc plows.
Ronald in NWMO
10-24-2017 09:48:50
What is the advantage of using a disc plow compared to a moldboard plow? I don't remember seeing a disc plow in northern MO back when everyone plowed. I see a few now in collections but they are still very unusual around here. Nice pictures and thanks for posting.
Case Nutty 1660
10-24-2017 17:13:43
 Re: 403 disc plow in reply to Ronald in NWMO, 10-24-2017 09:48:50
Pulls easier, can plow deeper, works in hard packed down ground better, breaks up the material better in most conditions, this one can cut up to 14" deep, according to Case they were mainly for the California irrigated deltas I think is how they put it,, cnt
RBnWA
10-24-2017 07:02:14
cnt how fast can that be pulled and still do a good job. I ve never seen one in operation. RB
Case Nutty 1660
10-24-2017 07:04:59
 Re: 403 disc plow in reply to RBnWA, 10-24-2017 07:02:14
Depends on soil conditions, I was running 4.5 mph but in mellower soils I am sure you could run 5 -51/2 mph cnt
Dave8N in Pa
10-24-2017 06:39:04
That's an interesting plow. Did they make them bigger?
Case Nutty 1660
10-24-2017 07:03:18
 Re: 403 disc plow in reply to Dave8N in Pa, 10-24-2017 06:39:04
third party image
Yes they did but not in mounted models, they made up to a 6 bottom pull-type, it was Huge and took either a 4x4 or crawler to pull it, here is a pic I had handy of a four bottom with smaller discs than the 5and 6 bottom ones had
cnt
rgorange
10-24-2017 07:25:38
 Re: 403 disc plow in reply to Case Nutty 1660, 10-24-2017 07:03:18
Looks like a new unit. Why do you suppose they are towing it backwards in the pic? Just took it off the truck??? Seems like they would have hooked it up correctly for the photo op.
Case Nutty 1660
10-24-2017 07:39:54
 Re: 403 disc plow in reply to rgorange, 10-24-2017 07:25:38
That is transport mode
cnt
