1370 case tractor with power shift problems
lobo8l
09-25-2017 18:03:43
HELP the tractor dies if i step in the clutch or if i shift the power shift to reverse hope some one can help me thanks for looking
lobo8l
09-26-2017 09:16:38
 Re: 1370 case tractor with power shift problems in reply to lobo8l, 09-25-2017 18:03:43
Quoting Removed, click Modern View to see no it isn't that either took out all four spools and the were all nice and shinny put it back together and it still does the e-same thing e en turned the motor over and shot some oil out of the spool holes didn't help but thanks for the thought
1370rod
09-26-2017 18:32:11
 Re: 1370 case tractor with power shift problems in reply to lobo8l, 09-26-2017 09:16:38
If the spools are all free and operating properly you have a problem in the power shift itself. Rod.
lobo8l
09-26-2017 06:03:46
Sorry i have never worked on a 580 so can't tell ya about that 4020 i have one of those i have worked on put a motor out of a 7700 JD combine in it more power then has had since i have had it. Threw some magnets in the rear end on it to collect the metal filings in side the filters so one of these days i guess i will have to take apart the brakes on the left side ...
lobo8l
09-26-2017 05:58:35
Quoting Removed, click Modern View to see thanks Rod I will pull that one out and see if its the problem I have had the tractor for six years and i know the 1st gear on the power shift slips so i get it going and shift into second right away but even now I slow the throttle down and shift up and then down and i can pull tin gear and drive it as long as i just go forward third gear on the power shift labors so i didn't;t run that but i was 6 miles from home when it started the problem and at least i got it home...
1370rod
09-26-2017 05:14:15
The problem sounds like C-3 pilot spool is stuck, but regardless the best thing to do is remove the entire control valve and clean all spools and their bores. After that job is done make sure new hyd filters are installed and maybe oil if needed. Rod.
Twn
09-25-2017 20:18:08
could you tell my post on the 580 case power shuttle problem and hello me out if you can please thanks
rndy3788
09-25-2017 20:08:06
stuck spool in the valve on right side of transmission if your lucky that's all it is, keep your fingers crossed
