case vai push rod tubes
flyingpolock
09-08-2017 14:37:50
Hello, i have a few push rod tubes that are bad. I need to replace em. These arent push rods, but but the tubes they go through. Part no. Is VT-3224. Can anyone tell me where i can purchase these? Phone numbers? Or have any? Or a way to make them? Reply on here or text me at 585-808-6288. Thanks Mike!
Joe (Wa)
09-08-2017 18:54:38
 Re: case vai push rod tubes in reply to flyingpolock, 09-08-2017 14:37:50
The pushrods' tube p/n VT3224 was changed to A29262. You could try a Case dealer with the later p/n but I suspect they are no longer available. You will probable have to take them from a salvage head. Same tubes in all VA series engines and in all 300 148 cid engine heads.
Don L good choice, call AM best.
Joe
flyingpolock
09-08-2017 17:49:10
Yeah alot of people think thats what i mean. You can actally see em on the outside of the engine.
flyingpolock
09-08-2017 17:47:11
Jon f mn
09-08-2017 17:37:32
I thought you wanted push rods, sorry. Call Don Livingston at 5074330073.
