Vai gear ratios
1961casepuller
05-16-2017 15:32:17
So I have a 49 vac row crop that I tractor pull it has 38 inch rear rubber and in 2nd gear it runs way to fast for our mile per hour class. I have found an industrial less than 30 miles from my house that I can buy cheap my question is,"would the vai have a slower ratio in the rear end or transmission?" Thanks and all help is greatly appreciated
Adirondack case guy
05-17-2017 15:54:02
 Re: Vai gear ratios in reply to 1961casepuller, 05-16-2017 15:32:17
Am I missing something here???? Why don't you just put in First gear
Loren.
1961casepuller
05-17-2017 21:40:07
 Re: Vai gear ratios in reply to Adirondack case guy, 05-17-2017 15:54:02
This tractor has a 201 gas out of a combine that has been bored and stroked so torque is not an issue
1961casepuller
05-17-2017 21:38:19
Then I'm to slow I pull 8 miles per hour and first puts to much torque but not enough speed second puts my torque right at the rear wheels but is to fast I'm at 10 miles per hour in second and 6 in first going down the track
josh hagan
05-17-2017 07:07:36
Not sure how to slow it down but I do know if you put bigger tires on the Vai they are scary fast
mattwillson
05-16-2017 17:23:37
Not likely as it should have 24" rubber, which will slow it down. Neighbour's vai has a different shift pattern vs dad's vac13, maybe there's a difference in the trans gearing.
1961casepuller
05-16-2017 18:49:16
 Re: Vai gear ratios in reply to mattwillson, 05-16-2017 17:23:37
Any ideas on how to slow it down with the tall rubber
kub6040
05-21-2017 11:25:38
 Re: Vai gear ratios in reply to 1961casepuller, 05-16-2017 18:49:16
may use first gear with a vai as I think it would be faster.
