injection pump question
Cariboo4x4
04-30-2017 09:00:51
On my 1961 Case Backhoe\loader W3 (530) there is a pipe plug directly opposite of the fuel inlet on the roosta master injection pump. I used a 3/8" open end wrench to tighten it a bit because it was dripping diesel slowly. It actually felt loose so tightened it about 1 turn. I can't seem to find any info on this "plug". Before I run my engine does anyone here know if its just a drain plug or a adjuster of some sort? Thank you in advance
Cariboo4x4
05-01-2017 07:58:06
 Re: injection pump question in reply to Cariboo4x4, 04-30-2017 09:00:51
The plug is metal, it just has a square nub to attach a wrench. Thank you for the offer and help fellows.
thepumpguysc
04-30-2017 10:17:23
That plug is used by the rebuilder to adapt to a pressure gauge to read transfer pump pressure at various speeds inside the pump.. its then plugged..
That baby must be old because they changed that plastic plug to a metal plug w/ an oring back in the 70's.
I have hundreds laying around if you would like one.. TPG
Dieseltech
04-30-2017 10:13:39
That's the pressure tap port for the transfer pressure gauge when the pump is calibrated on the test bench..
