manifold repair
s,mac
01-31-2017 21:08:25
As you can see there is a large hole in the exhaust manifold. I am thinking how to make a cheap temporary repair until a better manifold can be found. I found some cold weld steel that is good to 2400 degrees and using that to attach a piece of copper over the hole. Then wrapping it header wrap. I thought about brazing it but my luck it would crack and make matters worse. Any thoughts would be appreciated. Steve
C. Amick
02-01-2017 17:18:32
 Re: manifold repair in reply to s,mac, 01-31-2017 21:08:25
I braised a steel patch onto my Case SC manifold and it has been on there for years. It was a flat surface that I patched so it was probably an easier repair than what you need to do.
mschwartz
02-01-2017 10:59:24
Hello Steve, did you get any pictures that I sent you yesterday? When I got back home Sunday it had warmed enough to melt snow off mostly so I was able to take a couple pics of my parts tractor for you, snowed another six inches since then so I guess still winter. Did not have a picture of it but I did have a manifold that looks good except one ear is broken off the carb mount side. Run ok on my '38 I just used the better one off of the combine motor. Thanks, Mike.
s,mac
02-01-2017 13:02:51
 Re: manifold repair in reply to mschwartz, 02-01-2017 10:59:24
Hello Mike no email or pictures. Thanks Steve
Rick in Iowa
02-01-2017 10:05:44
Quoting Removed, click Modern View to seewhats the manifold off of?
s,mac
02-01-2017 07:55:03
third party image
oldproudvet
02-01-2017 07:14:00
You would have to pre heat that cast piece, to even have a prayer of success. If the hole is from corrosion, I wouldn't even think about brazing. Some epoxy's are magic, if you can get it clean enough for good adherence.
