Convert from LP to gas
corybtex
09-04-2016 19:57:16
I have a 930(941) that has an Impco 100 conversion system on it and I am considering converting from LP to Gas for convenience and better economy. Any help, idea's, suggestions would be great.
brokengun
09-06-2016 20:12:37
 Re: Convert from LP to gas in reply to corybtex, 09-04-2016 19:57:16
You can solve the vapor problem caused by the LP intake manifold by welding or bolting a piece of steel between the intake and exhaust manifold. think muffler clamps and a 3/8 thick piece of steel about 3" wide
Paul A Young
09-05-2016 18:21:59
I have a carb. That has been rebuilt that was on my 930 when I got it. It is not the factory carb. But runs just fine with it. It is for sale. The problem you are going to have is your manifolds for LP are not made to transfer heat from exhaust to intake. Without that the tractor will not run well at all. Maybe you have already thought of this and addressed. Calls are best (309)314-6653 Paul
lp-always
09-05-2016 17:54:37
I know LP is a pain when it comes to filling the tank, but you get better economy on propane
corybtex
09-05-2016 13:20:05
Can anybody tell where to find a carburetor or does somebody have one lying around
Richard G.
09-05-2016 09:46:51
I switched a 51 Case LA and it did great. Had plenty of power.
Richard
NickatKY
09-05-2016 06:44:39
I prefer LP gas. I just filled my tank this summer for 89.9 cents a gallon. LP will never go bad like gas. The biggest draw back is filling the tank. I have a 20lb grill tank for back up if I run out in the field. Nick
