Case 530ck
James20042
06-11-2016 21:15:04
Hello, I purchased a 530ck today and was told it may need a flywheel. It will move but will not climb a hill. Seems to lack power but the engine runs strong. Is there a way to test and be sure? Anything I should try first? Thanks
James20042
06-11-2016 22:19:18
 Re: Case 530ck in reply to James20042, 06-11-2016 21:15:04
From what I remember there was a hi/low lever on the right side,gear shift in middle and a forward/reverse lever on left side. I don't recall any lever on the right side by steering wheel only the throttle.
dacaseguy
06-11-2016 21:31:48
Is it a direct drive or a torque converter drive. If it is a torque converter it should have a small lever on the steering colum like the throttle lever but on the opposite side. A flywheel is not the most likly problem. Dick
James20042
06-12-2016 17:03:26
 Re: Case 530ck in reply to dacaseguy, 06-11-2016 21:31:48
It does have that lever .
James20042
06-11-2016 21:40:34
Sorry I meant to say torque converter. I'm not sure about the lever I will have it in my possession tomorrow.
