1070 neutral saftey switch
barthski
03-18-2016 06:58:45
Is there a neutral saftey switch on a 1070 case and where is it located.
mEl
03-19-2016 06:51:42
 Re: 1070 neutral saftey switch in reply to barthski, 03-18-2016 06:58:45
There are .010 shims under the NS switch, test it with an ohmmeter and if it closes when you push the ball in try removing a shim and retrying it, you may save the price of a switch.
Jicase#1
03-18-2016 07:56:11
Yes there is a neutral safety pull the center platform cover off and its right on top of transmission
