David Brown 3 pt hitch hydraulic problem
Ed Behun
03-12-2016 08:53:35
I have a 990 DB selectomatic that has a problem with the 3 pt hitch. When I start it up the 3 pt hitch goes all the way to the top with the control lever all the way down. The problem began when my nephew knocked off the weld stop located on the control holder. Subsequently the 3 pt went up to the top and remained there. I took the control valve housing to a Case dealer but all they knew to do was clean it.
Adirondack case guy
03-13-2016 15:59:49
 Re: David Brown 3 pt hitch hydraulic problem in reply to Ed Behun, 03-12-2016 08:53:35
If your selector knob is in the TCU selection, and you push the position control lever forward in the quadrant where the blue decal is the hitch arms will rise. Pull your position lever all the way back, and then further against the spring, and then while holding it there turn the selector knob to position control (red) and see if everything works properly then.
Loren
