Splitting 411 problem
KennyCase
03-04-2016 21:23:58
Can anyone tell me what I'm doing wrong? I'm am splitting my 411 and when doing so I can not seem to get the input shaft to come out of crankshaft, I have split it apart about a foot. It seems to be loose inside the transmission but tight in the crankshaft. Any suggestions would be awesome.
Ken
Case Nutty 1660
03-05-2016 07:23:53
 Re: Splitting 411 problem in reply to KennyCase, 03-04-2016 21:23:58
if you have it a foot apart all should be free,,, only thing I can think of is maybe the pilot bearing is stuck on the trans shaft,, never seen one move that far and not come apart
cnt
Chuck Machinist
03-05-2016 03:42:42
You may give us an idea how you are supporting the rear and the motor end of the tractor. As you split her, she may have dropped{bowed} at the split. Take up on the motor end slightly, to get her out of the bind . Are you working with a service manual? Chuck
KennyCase
03-05-2016 05:14:42
 Re: Splitting 411 problem in reply to Chuck Machinist, 03-05-2016 03:42:42
I have both ends held up with stands. I've tried raising and lowering. Can't seem to get it to budge. Yes I have a manual to go by. I've split a couple tractors before but never this small, and never had this problem.
Ken
KennyCase
03-05-2016 07:22:50
 Re: Splitting 411 problem in reply to KennyCase, 03-05-2016 05:14:42
Well I got the shaft out. All I did was walk in the shop today and touched the shaft and it came right out! The power of just letting it sit over night.
Chuck Machinist
03-05-2016 11:44:02
 Re: Splitting 411 problem in reply to KennyCase, 03-05-2016 07:22:50
Make sure to post your progress with pictures Kenny!
