Parts insanity
RGMartin
Rebuilding an Agriking seat for my 1070. A60330, rubber bushings that go in the seat suspension on a 70 series... $98.50 each... It takes 8... Can buy a complete air ride for less than that.
I know the frustration as things we want to repair and parts are still available but at prices that make it unreasonable. I priced those a year or so ago and ended up tossing the old seat and putting in a new one. Rod.
Sounds like Case and Agco are first cousins?
But then I priced a temp gauge cable and sending unit for a lil' stinkin' 420 JD a few years back and JD wanted $140.
There are bushing out there at reasonable prices . The problem is find the correct size and type. I did some googling and came up with different ones. Also, I don't know it those are all rubber or have a steel insert. Lot of combines use similar bushing on the grain pan shaker arms etc. I looked at Messick's and they wanted 100 bucks for your bushing.
Steel sleeve on the outside, rubber, then steel bushing on the inside.
OD is 1 1/8", ID takes a 5/8" bolt, 1" long.
I am planning on a steel sleeve on the bolt, and a nylon or rubber chassis bushing on that. Should cost $50 or less for the lot.
Hi me and agco/ alo quickie are about to have words over the $120 each they want for loader grapple tines.
I found out by accident Case IH have the same tine, only 2 differences agco part starts with AL and Case starts with LDR then same numbers after. other difference is the price. Case IH only want $50 for the same tine!!!!!.
I was not real happy with agco when I found that out. I got 10 tines from them as I wreck atleast 3 of them a time cleaning out frozen hog barn manure.
Regards Robert
