Company Logo Shop Now
Case 300 and Baler Question
Bobl1958
02-16-2015 15:03:13
Just wondering if my little 1958 Case 300 Roundnose would be strong enough to pull a JD 336 baler on fairly flat ground. Probably only bale 300 - 400 bales per year but wondering if it might be too hard on the tractor. Tractor is in good shape, but mainly worried about the PTO. Next tractor up is 135hp so looking for something a little smaller. What are your thoughts? Thanks - Bob
mndan
02-16-2015 17:41:55
 Re: Case 300 and Baler Question in reply to Bobl1958, 02-16-2015 15:03:13
Bob- I have a 336 and have used it for about 16 years. I first pulled it with a Farmall 450 and it made her work. Ours has a thrower on it so that takes a little more power and when you pull a cage rack behind it it can get pretty heavy and push you around. If you don't have a thrower and you're not going to pull a wagon you will probably be ok with the 300. But you will definitely not be able to use the full capacity of the baler. They can really eat the hay! Hope this helps. Dan
C. Amick
02-16-2015 17:24:01
I don't know anything about a JD 336, but I have ran a MF 12 baler with my 300. Only problem I had was the 300 drawbar was a little too low. I have also ran the MF 12 with a Case SC.
Today's Featured Article - Old Abe is Still Making Hay - by Jeremy Sweeten. Things have changed a bit since my last article. I am now almost finished graduate school at Purdue University. I am still in Agronomy, but specializing in hay and forages. My wife has survived two years of marriage to a part-time farmer. The equipment line up has changed a bit too. The DC has retired to ... [Read Article]
Latest Ad: JD 420 -430 crawler 3 pt. center link 3 parts [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
