Fred in Utah
I had my tractor running a couple weeks ago and then it just quit...seemed like it was a fuel problem. I found the problem yesterday. There is a fuel shut off valve right below the fuel tank on the right side.... It's supposed to have a little screw lock keep it in so it won't fall out. The other week I pulled all the way out and fuel sprayed everywhere...I thought oh that's not good and shoved it all the way back in So, yesterday when I'm changing the fuel filter's there's no fuel coming out and I'm asking myself what's wrong with this picture...so I pulled out the stopper....duh...I created the problem. At least my diagnosis was correct...it wasn't getting any fuel! Now that it's running I have a few more questions. The PTO won't shift into gear with out grinding, I assume it's the two stag clutch...how hard are they to fix, and can I get parts? While I'm in there is there anything else I should replace? Thanks
