Hi, I recently rewired my 830 and found a broken
wire at the fuel sending unit. After fixing the wire
the gauge still doesn't work. It stays on empty.I
have 12 volts at gauge and 0 volts at wire
connection at sending unit. I took a test light from
pos. battery post to tank and get no light.That
tells me the tanks not grounded. Will the gauge or
sender work if that's the case? do i need to ground
the tank? Can i run a wire from a screw that mounts
the sending unit to ground? Thanks for any help.
