Company Logo Shop Now
RC lower radiator hose
mschwartz
01-11-2015 20:38:15
Hello, need some help with the lower water inlet on the block of RC? How is the elbow supposed to attatch to the block? Tractor has the FC waukesha motor. Tractor has a jam bolt welded to the mag base right now. Looking at my parts tractor I am wondering if it should be a bolt into the block or maybe a stud in the block? Thanks, Mike
casenut1
01-11-2015 23:24:33
 Re: RC lower radiator hose in reply to mschwartz, 01-11-2015 20:38:15
The elbow has a bolt that goes thru it into the block. They are usually rusted off in the water jacket area.
mschwartz
01-12-2015 07:29:45
 Re: RC lower radiator hose in reply to casenut1, 01-11-2015 23:24:33
Ok, that is what I suspected, will try cleaning up block and see what I find. Do you happen to know what the bolt is threaded into? Will I be drilling out broken bolt into water jacket? Blind casting or crankase? Thanks, Mike
casenut1
01-12-2015 17:23:57
 Re: RC lower radiator hose in reply to mschwartz, 01-12-2015 07:29:45
Right in the center of the hole you should see the end of the broken bolt. I believe it is in the block but doesn't go all the way thru. Be careful and not drill any deeper than the bolt . You have to drill it out then re-thread for a new bolt.
Today's Featured Article - ... [Read Article]
Latest Ad: John Deere wheels rare pair of A1106R 24 inch solid cast rear wheels 3000.00. Pair of BWH / BNH 40 inch spokes 1600.00 pair of John Deere D front spokes 350.00. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
Binary file (standard input) matches
