Case Tractors Discussion Forum |
mEl, Thanks! 930 LP Ignition
Author |
[Modern View] |
Camboted
01-02-2015 03:44:29
mEl, Thanks for the advice on the electronic ignitions for the 930 LP's. I'm tempted to try the "Ignightor 2" but it says on the regular "Ignightor" posting that you have to replace cap and rotor, but no mention of this on the "Ignightor 2". I know I have two different types of distributors and if I remember correctly the one type has no parts available. The caps look ok but I'd hate to bring those kits here and no be able to use them. What do you think? Anyone else know? Jump on!
mEl
01-02-2015 05:17:53
Re: mEl, Thanks! 930 LP Ignition in reply to Camboted, 01-02-2015 03:44:29
Ted, I would just get the cap n rotor. The rotor is the drive mechanism for the module, the magnet ring has wings that stick straight up and the rotor sets down in it. The cap and rotor are a set. I had to change the 7-870s also. It sounds like they have addressed a slight problem present in the IG1, I believe they mentioned overload protection in the description.
This issue was more prevalent on 4 cylinder engines than 6s due to the fact that 4s had more dwell time and the module could overheat and fail. Coil Ohms is critical. 4 Ohms primary is required and I would go one step further and install a ballast resistor in addition as the unit will work quite well with the added resistance which will serve as protection from over current .
Keep in mind that this modification will be very polarity sensitive, improper jump starting or any reverse polarity voltage can fail the module.
Due to the fact of where your work is located I think keeping a spare is prudent. mEl
01gentdc
01-02-2015 06:54:11
Re: mEl, Thanks! 930 LP Ignition in reply to mEl, 01-02-2015 05:17:53
Happy New Year .Guys ...... a spare or 2 is a good idea ... Ted ,, I think you will like electronic ignition ,, best thing I ever done folr the DC ,, that ol Gent simply will not take No for answer ,,.
700KK
01-02-2015 05:13:59
What parts are not available.
Camboted
01-02-2015 18:25:19
Re: mEl, Thanks! 930 LP Ignition in reply to 700KK, 01-02-2015 05:13:59
mEl. I need to go look at the tractors, but a few years ago I needed parts and, if I remember correctly, there were Prestolite and Delco distributors, and one of them didn't have caps, points and rotors available. I'll check the makes and get back to you.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
... [Read Article]
Latest Ad:
Complete set of 12 inch John Deere BO Lindeman pads. Very nice shape
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
