Company Logo (800) 853-2651 Shop Now
AlanFieldMaster or anyone else
agman
12-04-2014 09:51:15
I now have the exact same problem. Did you figure out where your problem was? Slip in PS2 and PS3. Works fine in all gears in PS1 and R.
https://www.yesterdaystractors.com/cgi-bin/viewit.cgi?bd=case&th=256199
1370rod
12-04-2014 10:51:00
 Re: AlanFieldMaster or anyone else in reply to agman, 12-04-2014 09:51:15
Generally speaking slipping in 2 or 3 powershift will quite often be caused by a leak in both those circuits. If this is a 70 or 90 series tractor my first guess would be loose or broken C2,C3 hub bolts. I would suggest a pressure test to confirm that guess. Rod.
agman
12-04-2014 13:47:47
 Re: AlanFieldMaster or anyone else in reply to 1370rod, 12-04-2014 10:51:00
Where you located 1370 rod?
agman
12-04-2014 13:46:06
What pressure checks do you recommend and what pressures am I looking for. You say broken hub bolts, but it runs fine with out load and in lower gears, it is when you load it down or push it ahead in 4 where it feels it is just spinning. Does it need to be split?
1370rod
12-04-2014 16:30:04
 Re: AlanFieldMaster or anyone else in reply to agman, 12-04-2014 13:46:06
What model tractor do you have, that will make a difference in what I suggest you do. Live in southern MN, Rod.
agman
12-04-2014 18:46:40
 Re: AlanFieldMaster or anyone else in reply to 1370rod, 12-04-2014 16:30:04
1976 Case 1370
1370rod
12-04-2014 20:45:50
 Re: AlanFieldMaster or anyone else in reply to agman, 12-04-2014 18:46:40
Idle tractor as slow as it will run with it warmed up some. Observe trans press gauge in 1 and then 2 and then 3 powershift. The gauge reading should be the same in all positions. Then shift to 1 powershift with the 3pt arms down all the way, then move 3pt lever quickly to full raise and take note on how fast the arms raise. Do the same test to 2 and 3 powershift. The arms should raise at the same speed in all shift positions. If there is a difference in gauge pressure and lifting speed, that would indicate a leak. You can try calling me at 507 926 5229 with the results and I can explain much easier over the phone what is going on and what you will have to do. Rod.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
