Case Tractors Discussion Forum |
case 1370 trans stalls or slips
Author |
[Modern View] |
jicase#1
11-03-2014 08:25:05
my late model 1370 seems to stall or slip once in a while when using it has good trans pressure i noticed this when I was chisel plowing the other day it would surge like when I would drop the implement down and then it take right off agian just woundering if it would be in the valving or something more major! It happend when i was running it in 3rd gear 2nd range if that helps any good info would be great thanks
1370rod
11-03-2014 17:49:08
Re: case 1370 trans stalls or slips in reply to jicase#1, 11-03-2014 08:25:05
If you can get it to slip in all the power shift speeds, 1,2+3, then the torque limiter is more than likely slipping. If it only slips in one or two of the speeds then more than likely a clutch pack in power shift is slipping. Rod.
jicase#1
11-03-2014 19:45:13
Re: case 1370 trans stalls or slips in reply to 1370rod, 11-03-2014 17:49:08
Rod..I checked the valve banks on the powershift for the pressures all the banks read 200psi until i checked the c1 and c3 banks it would only put out 110psi put 1 shim in the pressure regulater and it brought it up to150psi was gonna put another shim in and check it but ran out of time do you think maybe just the spring is week in regulator in it?
1370rod
11-04-2014 05:18:35
Re: case 1370 trans stalls or slips in reply to jicase#1, 11-03-2014 19:45:13
If some read 200 psi they all should read approx. that. Shimming the pressure reg. in the flow divider will raise all the pressures because that single setting controls the pressure for all clutch packs. A difference of more than 10 psi among circuits would indicate leakage in the ones with lower pressure. Rod.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play
... [Read Article]
Latest Ad:
John Deere 820 tractor in very good condition.2 owner tractor with original rear tires. 715 853 3669
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
