On the case ih parts online website, the 1370 telescoping steering wheel looks like the same design as my 2590.
There are two rubber "keys" that wear out. They are available from case but I made two from a rubber tarp strap, just cut to size, about 6mm x 6mm x 12-15mm long.
The hardest part of the job was getting an internal lock ring washer part out of the column so the lock mechanism can be removed from the column.
I pulled the steering out of the cab by removing it at the u-joint under the dash.
I can't seem to copy and paste the parts image on this device.
