Company Logo (800) 853-2651 Shop Now
Part # G12150 service tool
chuck machinist
10-18-2014 16:50:34
This tool is a Spark plug tire pump with a 12 foot hose. My question is, when using this tool {inserting tool in spark plug hole] do you start the motor, or do you pull the coil wire, then turn the motor over? Short bursts of 10 to 20 seconds, so as not to burn up the starter . One more Barley Pop Linda!
case1939
10-19-2014 11:02:41
 Re: Part # G12150 service tool in reply to chuck machinist, 10-18-2014 16:50:34
I have one of them. The instruction's say if you don't want gas vapors in you're tub back off you're valve push rods so the valves do not open. Mine can suck air in throw the brass fitting that screws in to the spark hole.
Bruce
Adirondack case guy
10-18-2014 18:15:41
Yup, blow up your tires with that and run the milking machine with the valve cock on the intake manifold. As a kid. I remember many a winter night up at the farm with the SC running down the isle of the cow barn to milk the cows when the power was off.
Loren
chuck machinist
10-18-2014 17:54:17
 Re: Part # G12150 service tool in reply to Joe (Wa), 10-18-2014 16:50:34
Thanks Steve. I remember dad keeping a spare tire in the truck and transfer air from one tire to the other. If it wasn't for Barney and the Goodyear service truck, we would have been in a bad way. What was Barney's last name Pastor John? What we take for granted today, hey!
timbernt
10-18-2014 17:38:06
I am 57 years old and like casecollector it was the only way I remember my Dad inflating a tire until I was about 10. And it was always the DC he used.
RGMartin
10-18-2014 17:37:17
So you are getting a gasoline/air mix in your tires????
Christopher Mikesell
10-18-2014 18:28:49
 Re: Part # G12150 service tool in reply to RGMartin, 10-18-2014 17:37:17
Yes, you are. It is hard on tubes over time. But, if the tube is already leaking, then it doesn't matter much. Also, tubes used to be made from much thicker rubber than they are today.
casecollectorsc
10-18-2014 16:59:54
Start the engine as normal. Was the only air compressor we had as a kid. It went in a plug hole on the DC.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: WD45 Allis Chalmers tractor that needs some reassembly or will make a great donor tractor. I have the motor torn down currently and due to life changes, I need to sell. Tractor has Firestone 16.9x28 tires. Good metal,, carb, block, manifold, head, etc. Price is negotiable for cash. Calls only 7am to [More Ads]
Copyright © 1997-2022 Yesterday's Tractor Co.
